Salta al contenuto principale
How To Patch A Hole In The Wall
Cosa ti serve
  1. How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: passo 1, immagine 1 di 3 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: passo 1, immagine 2 di 3 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: passo 1, immagine 3 di 3
    • Sand down the hole and the area surrounding. This is in order to get paint off the wall.
  2. How To Patch A Hole In The Wall: passo 2, immagine 1 di 2 How To Patch A Hole In The Wall: passo 2, immagine 2 di 2
    • Use the rag and the toothbrush to clean off any excess rubble near the hole.
  3. How To Patch A Hole In The Wall: passo 3, immagine 1 di 1
    • Follow the directions on the spackle box to prepare the spackle for application.
    • Although all spackle brands are different, spackle should have a consistency similar to toothpaste when mixed with water.
  4. How To Patch A Hole In The Wall: passo 4, immagine 1 di 3 How To Patch A Hole In The Wall: passo 4, immagine 2 di 3 How To Patch A Hole In The Wall: passo 4, immagine 3 di 3
    • Take the spackle mix and apply it to the hole.
    • Make sure to layer the spackle evenly and remove excess spackle.
  5. How To Patch A Hole In The Wall: passo 5, immagine 1 di 1
    • Wait 30-45 minutes for the spackle patch to dry.
    • Wait time may vary depending on the depth of the hole and spackle mix used.
  6. How To Patch A Hole In The Wall: passo 6, immagine 1 di 1
    • Make sure the spackle is dry.
    • Sand the spackle until it is smooth and flush with the wall.
Conclusione
Now your wall should be looking as good as new!
Altre 3 persone hanno completato questa guida.
Joseph Garcia
Membro da: 09/29/15
293 Reputazione
1 Guida realizzata
Cal Poly, Team 17-2, Green Fall 2015 Membro di Cal Poly, Team 17-2, Green Fall 2015
CPSU-GREEN-F15S17G2
4 Membri
8 Guide realizzate
Un commento
I suggest using a sanding sponge or block in step 6
Dennis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,486
