Introduzione
A damaged or broken hook can make an otherwise perfectly fine bra suddenly unwearable. This guide shows how simple and quick this all too common issue can be fixed.
Cosa ti serve
Use a seam ripper to rip off the seams on either side of the broken hook and also the edge seam.
Tada! You saved your bra from an early grave in the dump!
Altre 11 persone hanno completato questa guida.
9 Commenti
What size hook do I need?
Thank you . you took it from being overwhelming to …. Its fixed. Yippeee thank
Your instructions were super clear — It works!!! Thank you!
beautiful instructions. thank you for clear pictures too. i knew it was possible but it was nice to see a step by step.
