Salta al contenuto principale
How To Fix a Broken Bra Hook
Cosa ti serve
  1. How To Fix a Broken Bra Hook, How To Fix a Broken Bra Hook: passo 1, immagine 1 di 3 How To Fix a Broken Bra Hook, How To Fix a Broken Bra Hook: passo 1, immagine 2 di 3 How To Fix a Broken Bra Hook, How To Fix a Broken Bra Hook: passo 1, immagine 3 di 3
    • Use a seam ripper to rip off the seams on either side of the broken hook and also the edge seam.
    • Make sure to not rip off the seam of other hooks.
    • Point the head of the seam ripper away from you to prevent poking yourself
  2. How To Fix a Broken Bra Hook: passo 2, immagine 1 di 3 How To Fix a Broken Bra Hook: passo 2, immagine 2 di 3 How To Fix a Broken Bra Hook: passo 2, immagine 3 di 3
    • Remove the broken hook from the strap.
    • Pull or cut off the threads that are still attached to the strap.
  3. How To Fix a Broken Bra Hook: passo 3, immagine 1 di 1
    • Insert the new hook into the strap.
    • Use fingers to hold the hook in the strap.
  4. How To Fix a Broken Bra Hook: passo 4, immagine 1 di 3 How To Fix a Broken Bra Hook: passo 4, immagine 2 di 3 How To Fix a Broken Bra Hook: passo 4, immagine 3 di 3
    • Place the tip of the pin next to the new hook.
    • Make sure the pin is placed in the middle of the hook.
    • Push the pin until it goes through the strap and reach for back of the pin.
    • Point the tip of the pin next to the other side of the hook.
    • Push pin again to make it go through to the front of the strap.
    • Push the pin slowly to avoid poking yourself!
  5. How To Fix a Broken Bra Hook: passo 5, immagine 1 di 1
    • Put the hooks into the eyes of the bra to make sure hook is placed correctly.
  6. How To Fix a Broken Bra Hook: passo 6, immagine 1 di 2 How To Fix a Broken Bra Hook: passo 6, immagine 2 di 2
    • Thread needle with thread the same color as the bra.
    • Pull the thread through to an appropriate length.
    • Approx. 10-12 inches.
    • Cut the thread.
  7. How To Fix a Broken Bra Hook: passo 7, immagine 1 di 1
    • Tie the thread into a knot at the end of the thread.
    • Tie two or three times for a thicker knot.
  8. How To Fix a Broken Bra Hook: passo 8, immagine 1 di 1
    • Cut the excess thread off with the scissors.
    • Do as close as possible to the knot for a clean seam.
  9. How To Fix a Broken Bra Hook: passo 9, immagine 1 di 2 How To Fix a Broken Bra Hook: passo 9, immagine 2 di 2
    • Feel around for one of the two holes at the bottom of the new hook.
    • This will not be visible and may take some time to locate.
    • Stick the threaded needle through the hole of the hook.
    • Use a backstitch to sew the hook into place.
    • Repeat this for the other hole in the same hook.
    • Always watch out for the tip of the needle while sewing!
  10. How To Fix a Broken Bra Hook: passo 10, immagine 1 di 2 How To Fix a Broken Bra Hook: passo 10, immagine 2 di 2
    • Make a large loop with the thread when finished sewing the hook into place.
    • Place your finger on the point where you would like the knot to be and pull on the thread.
    • Knot two or three times.
  11. How To Fix a Broken Bra Hook: passo 11, immagine 1 di 2 How To Fix a Broken Bra Hook: passo 11, immagine 2 di 2
    • Cut excess thread off with the scissors.
    • Do this as close as possible to the knot for no loose threads.
  12. How To Fix a Broken Bra Hook: passo 12, immagine 1 di 1
    • Remove the pin carefully.
  13. How To Fix a Broken Bra Hook: passo 13, immagine 1 di 1
    • Tie a knot at the end of the thread.
  14. How To Fix a Broken Bra Hook: passo 14, immagine 1 di 2 How To Fix a Broken Bra Hook: passo 14, immagine 2 di 2
    • Hand stitch the edge using a backstitch to close the seam.
    • Pay attention to the tip of the needle to avoid poking your fingers!
  15. How To Fix a Broken Bra Hook: passo 15, immagine 1 di 3 How To Fix a Broken Bra Hook: passo 15, immagine 2 di 3 How To Fix a Broken Bra Hook: passo 15, immagine 3 di 3
    • Tie a knot at the end when you finish closing the seam.
    • Hold finger down on the thread to make sure the knot is as close to the bra as possible.
  16. How To Fix a Broken Bra Hook: passo 16, immagine 1 di 1
    • Cut extra thread with the scissors.
  17. How To Fix a Broken Bra Hook: passo 17, immagine 1 di 2 How To Fix a Broken Bra Hook: passo 17, immagine 2 di 2
    • Try hook and eye to see if it fits appropriately.
Conclusione
Tada! You saved your bra from an early grave in the dump!
Altre 11 persone hanno completato questa guida.
Hang
Membro da: 10/26/18
425 Reputazione
1 Guida realizzata
UC Davis, Team S1-G7, Bender Fall 2018 Membro di UC Davis, Team S1-G7, Bender Fall 2018
UCD-BENDER-F18S1G7
3 Membri
1 Guida realizzata
9 Commenti
What size hook do I need?
joellewalters - Replica
Thank you . you took it from being overwhelming to …. Its fixed. Yippeee thank
Tracey Banish - Replica
Your instructions were super clear — It works!!! Thank you!
Michele King - Replica
beautiful instructions. thank you for clear pictures too. i knew it was possible but it was nice to see a step by step.
inspiredtosew - Replica
same never answered question: I need to buy new hooks: they seem to come in size 0-3.. what do I need???
nej - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 20
Ultimi 7 Giorni: 153
Ultimi 30 Giorni: 502
Tutti i Tempi: 39,738
