Salta al contenuto principale
How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan
Cosa ti serve
  1. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan, How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: passo 1, immagine 1 di 1
    • remove the three Phillips screws under the fan closest to the video ports of the card
  2. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: passo 2, immagine 1 di 1
    • Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
  3. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: passo 3, immagine 1 di 1
    • Reassemble and re-install the card into your computer. It should stop the vibration.
Conclusione
Altre 8 persone hanno completato questa guida.
Un commento
Can you post a picture showing how its fit in the fins?
Gustavo Horta - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 8,308
