Salta al contenuto principale
How To Fix A Swaying Fence Post
Cosa ti serve
  1. How To Fix A Swaying Fence Post, Fence Post: passo 1, immagine 1 di 2 How To Fix A Swaying Fence Post, Fence Post: passo 1, immagine 2 di 2
    • Measure from the center of the post to outer edges of the hole using the measuring tape.
    • Only measure out to the same width of the post itself.
  2. How To Fix A Swaying Fence Post: passo 2, immagine 1 di 3 How To Fix A Swaying Fence Post: passo 2, immagine 2 di 3 How To Fix A Swaying Fence Post: passo 2, immagine 3 di 3
    • Use the shovel to make an outline around post within the measurement made in Step 1.
    • Dig the hole about 1.5 to 2 feet down within the outlined area.
  3. How To Fix A Swaying Fence Post: passo 3, immagine 1 di 3 How To Fix A Swaying Fence Post: passo 3, immagine 2 di 3 How To Fix A Swaying Fence Post: passo 3, immagine 3 di 3
    • Use the post hole digger to take out dirt from the hole.
    • Be sure to take out all dirt so you are left with a flat base at the bottom of the hole.
    • If the hole is not deep enough, return to Step 2 and repeat until desired depth.
  4. How To Fix A Swaying Fence Post: passo 4, immagine 1 di 3 How To Fix A Swaying Fence Post: passo 4, immagine 2 di 3 How To Fix A Swaying Fence Post: passo 4, immagine 3 di 3
    • Open the bag of concrete and pour enough concrete to cover the bottom of the hole.
    • Add some water using the water hose to allow the concrete to become easier to mix
    • Add more water to create a balance between the amount of water and concrete inside the hole.
  5. How To Fix A Swaying Fence Post: passo 5, immagine 1 di 3 How To Fix A Swaying Fence Post: passo 5, immagine 2 di 3 How To Fix A Swaying Fence Post: passo 5, immagine 3 di 3
    • Add more concrete until the amount reaches just below the top of the hole.
    • Add more water to the mixture to allow the concrete to have a smooth consistency.
    • Again, balance the amount of water and concrete in the hole so there is not an excess of either in the hole.
  6. How To Fix A Swaying Fence Post: passo 6, immagine 1 di 3 How To Fix A Swaying Fence Post: passo 6, immagine 2 di 3 How To Fix A Swaying Fence Post: passo 6, immagine 3 di 3
    • Use a mixing stick and begin stirring the mixture of concrete and water.
    • Be sure to mix the contents of the hole thoroughly.
    • Keep stirring until you can feel a smooth consistency in the mixture. This will ensure that there are fewer pockets of air in the mixture.
    • The concrete will settle into the entire hole.
  7. How To Fix A Swaying Fence Post: passo 7, immagine 1 di 2 How To Fix A Swaying Fence Post: passo 7, immagine 2 di 2
    • While the concrete is setting, use the leveler to ensure that the post lies horizontally. To determine this, adjust the poles angle until the air bubble in the level floats in between the two line markings.
    • Apply this same procedure to ensure the post stands vertically straight.
    • Be sure to align the post itself until the air bubble floats between the two line markings of the leveler.
  8. How To Fix A Swaying Fence Post: passo 8, immagine 1 di 3 How To Fix A Swaying Fence Post: passo 8, immagine 2 di 3 How To Fix A Swaying Fence Post: passo 8, immagine 3 di 3
    • Use an electric drill to pre-drill holes into the bracing wood.
    • Be sure to apply pressure directly vertical and not at an angle.
    • Make sure you have room enough room to allow the bit to go all the way through.
  9. How To Fix A Swaying Fence Post: passo 9, immagine 1 di 3 How To Fix A Swaying Fence Post: passo 9, immagine 2 di 3 How To Fix A Swaying Fence Post: passo 9, immagine 3 di 3
    • Use the drill and 2 inch Torx #8 wood screws to drill the bracing wood into the post.
    • Angle the bracing wood diagonally from the post to the ground.
    • Align one of the pieces of brace wood to be perpendicular to the post and the other to be parallel to the post to prevent swaying while the concrete settles.
  10. How To Fix A Swaying Fence Post: passo 10, immagine 1 di 2 How To Fix A Swaying Fence Post: passo 10, immagine 2 di 2
    • Stand back and admire your work!
    • Wait for the concrete to fully settle before removing the bracing wood.
    • You may consider replacing the top of the hole with dirt. If not, the dirt may be repurposed.
Conclusione
Congratulations, you now have a strong and sturdy fence post! Feel free to take off bracing wood once concrete fully settles.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 29
Tutti i Tempi: 451
