Salta al contenuto principale
How To Fix A Hole In Khaki Pants
Cosa ti serve
  1. How To Fix A Hole In Khaki Pants, How To Fix A Hole In Khaki Pants: passo 1, immagine 1 di 1
    • Examine the damaged area.
    • Make sure to clean all the debris from the tear.
  2. How To Fix A Hole In Khaki Pants: passo 2, immagine 1 di 1
    • Flip your pants inside out.
  3. How To Fix A Hole In Khaki Pants: passo 3, immagine 1 di 1
    • Pinch hole together.
    • Make sure there is no gaps showing.
  4. How To Fix A Hole In Khaki Pants: passo 4, immagine 1 di 1
    • Pin needle and thread through pants.
    • Use more thread than needed so you will have enough.
    • Make sure your hand is not directly behind the needle where you are poking. This will prevent you from pricking yourself.
  5. How To Fix A Hole In Khaki Pants: passo 5, immagine 1 di 2 How To Fix A Hole In Khaki Pants: passo 5, immagine 2 di 2
    • Pull needle and thread through pants until there is only 2 inches of thread left.
    • Tie a knot at the end of the remaining 2 inches.
    • It can be any measurement, but 2 inches makes it easier to tie a knot without wasting too much thread.
  6. How To Fix A Hole In Khaki Pants: passo 6, immagine 1 di 2 How To Fix A Hole In Khaki Pants: passo 6, immagine 2 di 2
    • Take the needle and pin it through right next to the previous spot.
    • Pull all the way through until thread is tight.
    • Repeat this process until you reach the end of the hole.
  7. How To Fix A Hole In Khaki Pants: passo 7, immagine 1 di 1
    • Wrap the thread three times around the needle.
    • Pull the needle until the thread is tight.
    • This will tie a knot at the end.
  8. How To Fix A Hole In Khaki Pants: passo 8, immagine 1 di 1
    • Take the scissors and cut the excess string remaining.
  9. How To Fix A Hole In Khaki Pants: passo 9, immagine 1 di 1
    • Now put your khaki pants on because they are now wearable again and practically new!
Conclusione
Now your old ripped pants look practically new and you can begin wearing them again.
Altre 6 persone hanno completato questa guida.
Calvin Roth
Membro da: 09/27/15
291 Reputazione
1 Guida realizzata
Cal Poly, Team 17-1, Green Fall 2015 Membro di Cal Poly, Team 17-1, Green Fall 2015
CPSU-GREEN-F15S17G1
4 Membri
5 Guide realizzate
5 Commenti
it's 100% not ok...... i con do it so 99% ok
Shafikahmed - Replica
and 100% maching
Iam shafik i can't do it's and 100% maching
What about if you’re in school and your pants rip?
EMMA MILLER - Replica
is it smooth when you fix it? i use these for school and dont want it to show
JORDI ZAMUDIO - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 168
Tutti i Tempi: 51,377
