Salta al contenuto principale
How To Clean Nikon Coolpix S30 Lens
Cosa ti serve
  1. How To Clean Nikon Coolpix S30 Lens, Batteries: passo 1, immagine 1 di 2 How To Clean Nikon Coolpix S30 Lens, Batteries: passo 1, immagine 2 di 2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
  2. How To Clean Nikon Coolpix S30 Lens: passo 2, immagine 1 di 2 How To Clean Nikon Coolpix S30 Lens: passo 2, immagine 2 di 2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
  3. How To Clean Nikon Coolpix S30 Lens: passo 3, immagine 1 di 1
    • Remove the batteries by gently tipping the camera.
  4. How To Clean Nikon Coolpix S30 Lens, How To Clean Nikon Coolpix S30 Lens: passo 4, immagine 1 di 1
    • Remove the four screws the hold the back of the case to the rest of the camera.
  5. How To Clean Nikon Coolpix S30 Lens: passo 5, immagine 1 di 1
    • Remove the left screw from the bottom of the camera first. This can be done using the same T5 tip.
    • Unscrew the screw on the right using a different attachment: PH000 (it is a small Phillip's head)
  6. How To Clean Nikon Coolpix S30 Lens: passo 6, immagine 1 di 1
    • Remove back case from the rest of the camera carefully.
  7. How To Clean Nikon Coolpix S30 Lens: passo 7, immagine 1 di 1
    • Remove the three screws the secure the motherboard to the front case.
  8. How To Clean Nikon Coolpix S30 Lens: passo 8, immagine 1 di 2 How To Clean Nikon Coolpix S30 Lens: passo 8, immagine 2 di 2
    • Remove the motherboard from the front case.
    • Leave the red and black wire attached but lay the piece in front of the case.
  9. How To Clean Nikon Coolpix S30 Lens: passo 9, immagine 1 di 2 How To Clean Nikon Coolpix S30 Lens: passo 9, immagine 2 di 2
    • Wipe the lens and the clear plastic on the front case to remove debris.
Conclusione
Penn State, Team 2-4, Kaschak Winter 2015 Membro di Penn State, Team 2-4, Kaschak Winter 2015
PSU-KASCHAK-W15S2G4
4 Membri
5 Guide realizzate
Un commento
The first three steps are redundant because you already included the prerequisite guide for removal of the batteries.
Dylan Keiter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,787
