Introduzione
Before the repair, the speaker literally rattled like a bean in a pod— if I shook the headset I could feel it rattling. I preemptively repaired the other side too. Neither side rattles now at full volume, and the microphone works too.
Cosa ti serve
Using an awl or drift punch, mark a central location above the back of the speaker.
Gently by hand using a small twist bit, cleanly penetrate the plastic case. Stop when metal is visible.
work the adhesive into the glue port for example using a toothpick.
Gorilla glue can foam, so I taped over the glue port temporarily while the glue dried overnight.
Altre 3 persone hanno completato questa guida.
