Salta al contenuto principale
Hover-1 XLS LCD Screen Replacement
Cosa ti serve
  1. Hover-1 XLS LCD Screen Replacement, Ignition: passo 1, immagine 1 di 1
    • Remove the six 16mm #3 Hex head screws located on the front panel.
    • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
  2. Hover-1 XLS LCD Screen Replacement: passo 2, immagine 1 di 3 Hover-1 XLS LCD Screen Replacement: passo 2, immagine 2 di 3 Hover-1 XLS LCD Screen Replacement: passo 2, immagine 3 di 3
    • Grab the front panel and gently lift it up to the side.
    • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
  3. Hover-1 XLS LCD Screen Replacement: passo 3, immagine 1 di 1
    • Remove the two, 19 mm Phillips #2 screws holding the ignition.
    • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
  4. Hover-1 XLS LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 3 Hover-1 XLS LCD Screen Replacement, LCD Screen: passo 4, immagine 2 di 3 Hover-1 XLS LCD Screen Replacement, LCD Screen: passo 4, immagine 3 di 3
    • Remove the four 10mm Phillips #2 screws holding the casing of the LCD.
    • Remove the casing on the LCD.
  5. Hover-1 XLS LCD Screen Replacement: passo 5, immagine 1 di 3 Hover-1 XLS LCD Screen Replacement: passo 5, immagine 2 di 3 Hover-1 XLS LCD Screen Replacement: passo 5, immagine 3 di 3
    • Remove the four 10mm Phillips #2 screws holding the LCD onto the bike.
    • Gently lift off the LCD screen.
    • Follow iFixit's soldering guide to remove the LCD screen.
Conclusione
Cal Poly, Team S1-G2, White Winter 2019 Membro di Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,784
