Salta al contenuto principale
Hover-1 XLS Brake Replacement
Cosa ti serve
  1. Hover-1 XLS Brake Replacement, Front Brake: passo 1, immagine 1 di 3 Hover-1 XLS Brake Replacement, Front Brake: passo 1, immagine 2 di 3 Hover-1 XLS Brake Replacement, Front Brake: passo 1, immagine 3 di 3
    • Remove the two, 23 mm Hex #5 screws holding the brake to the bike.
    • Slide the brake mechanism off and turn it upside down to reveal the screw holding the brake wire.
  2. Hover-1 XLS Brake Replacement: passo 2, immagine 1 di 1
    • Remove the one, 14 mm Hex #4 screw pushing down the brake wire to the brake mechanism on the bottom.
  3. Hover-1 XLS Brake Replacement: passo 3, immagine 1 di 2 Hover-1 XLS Brake Replacement: passo 3, immagine 2 di 2
    • Remove the side screw holding the brake wire and mechanism together with your hands.
    • Slide the brake mechanism off from the brake wire.
Conclusione
Cal Poly, Team S1-G2, White Winter 2019 Membro di Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 20
Tutti i Tempi: 771
