Salta al contenuto principale
Hover-1 XLS Back Seat Light Replacement
Cosa ti serve
  1. Hover-1 XLS Back Seat Light Replacement, Back Seat Light: passo 1, immagine 1 di 2 Hover-1 XLS Back Seat Light Replacement, Back Seat Light: passo 1, immagine 2 di 2
    • Remove the seat by removing the six 16mm screws with a Phillips #2 screwdriver.
    • Remember that the seat is still connected by the wiring once you unscrew it. Pulling too hard can damage the connector.
  2. Hover-1 XLS Back Seat Light Replacement: passo 2, immagine 1 di 3 Hover-1 XLS Back Seat Light Replacement: passo 2, immagine 2 di 3 Hover-1 XLS Back Seat Light Replacement: passo 2, immagine 3 di 3
    • Disconnect the wires by pushing the levers on either side of the connector and on top.
    • Remove the seat from the bike.
  3. Hover-1 XLS Back Seat Light Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #2 screwdriver to remove the four 10mm screws on the bottom of the back seat.
  4. Hover-1 XLS Back Seat Light Replacement: passo 4, immagine 1 di 2 Hover-1 XLS Back Seat Light Replacement: passo 4, immagine 2 di 2
    • Pull the light from behind the bottom of the seat frame. Pull the wiring all the way through.
Conclusione
Cal Poly, Team S1-G2, White Winter 2019 Membro di Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 372
