Salta al contenuto principale
Hover-1 Ultra Power Button Replacement
Cosa ti serve
  1. Hover-1 Ultra Power Button Replacement, Power Button: passo 1, immagine 1 di 3 Hover-1 Ultra Power Button Replacement, Power Button: passo 1, immagine 2 di 3 Hover-1 Ultra Power Button Replacement, Power Button: passo 1, immagine 3 di 3
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the hoverboard.
    • Carefully remove the shell, lifting directly up.
  2. Hover-1 Ultra Power Button Replacement: passo 2, immagine 1 di 1
    • Unscrew the power button using your hands or an adjustable crescent wrench.
    • Turn the power button counter-clockwise to release from the shell.
  3. Hover-1 Ultra Power Button Replacement: passo 3, immagine 1 di 3 Hover-1 Ultra Power Button Replacement: passo 3, immagine 2 di 3 Hover-1 Ultra Power Button Replacement: passo 3, immagine 3 di 3
    • Unclip the red and black power cables that are attached to the port from the motherboard.
  4. Hover-1 Ultra Power Button Replacement: passo 4, immagine 1 di 2 Hover-1 Ultra Power Button Replacement: passo 4, immagine 2 di 2
    • Remove the power button from the hoverboard assembly.
Conclusione
To reassemble your device, follow the instructions for step 1 in reverse order.
UC Davis, Team S7-G5, Lore Fall 2018 Membro di UC Davis, Team S7-G5, Lore Fall 2018
UCD-LORE-F18S7G5
3 Membri
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 705
