Salta al contenuto principale
Hover-1 Ultra Charging Port Replacement
Cosa ti serve
  1. Hover-1 Ultra Charging Port Replacement, Charging Port: passo 1, immagine 1 di 3 Hover-1 Ultra Charging Port Replacement, Charging Port: passo 1, immagine 2 di 3 Hover-1 Ultra Charging Port Replacement, Charging Port: passo 1, immagine 3 di 3
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Hover-1 Ultra Charging Port Replacement: passo 2, immagine 1 di 2 Hover-1 Ultra Charging Port Replacement: passo 2, immagine 2 di 2
    • Using your hands or a crescent wrench, begin removing the charging port.
    • Turn the charging port counter-clockwise to release it from the shell.
  3. Hover-1 Ultra Charging Port Replacement: passo 3, immagine 1 di 3 Hover-1 Ultra Charging Port Replacement: passo 3, immagine 2 di 3 Hover-1 Ultra Charging Port Replacement: passo 3, immagine 3 di 3
    • Unclip the insulated red and black wires attached to the port from the motherboard
  4. Hover-1 Ultra Charging Port Replacement: passo 4, immagine 1 di 3 Hover-1 Ultra Charging Port Replacement: passo 4, immagine 2 di 3 Hover-1 Ultra Charging Port Replacement: passo 4, immagine 3 di 3
    • Remove the charging port through the assembly.
    • Place new charging port through the assembly.
    • Clip red and black insulated wires into the motherboard.
Conclusione
To reassemble your device, follow the instructions for step 1 in reverse order.
Altre 3 persone hanno completato questa guida.
UC Davis, Team S7-G5, Lore Fall 2018 Membro di UC Davis, Team S7-G5, Lore Fall 2018
UCD-LORE-F18S7G5
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 727
