Introduzione
Is your Hover-1 Ultra not charging to full battery, or not powering up at all? If you are experiencing these problems, it can be fixed with a very simple replacement of the charging port of your device. You will need a Phillips #1 screwdriver to remove the screws and an adjustable crescent wrench to remove the port
Cosa ti serve
Orient the hoverboard so that the pads are facing down.
With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
Carefully remove the shell, lifting directly up.
To reassemble your device, follow the instructions for step 1 in reverse order.
Altre 3 persone hanno completato questa guida.
