Introduzione
Is your Hover-1 riding slowly, dying while riding, or not going as fast? If you are facing these problems, a simple replacement of the battery could solve your issues. You will need a Phillips #1 screwdriver to remove the screws.
Cosa ti serve
Orient the hoverboard so that the pads are facing down.
With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
Carefully remove the shell, lifting directly up.
To reassemble your device, follow the instructions in step 1 in reverse order.
Un commento
Merci pour tous ces conseils précieux, j’ai pu réparer ma batterie de Hoverboard : https://hover-store.fr/batterie-hoverboa...
