Salta al contenuto principale
Hover-1 Titan Right Gyroscope Replacement
Cosa ti serve
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: passo 1, immagine 1 di 2 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: passo 1, immagine 2 di 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Right Gyroscope Replacement: passo 2, immagine 1 di 2 Hover-1 Titan Right Gyroscope Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Right Gyroscope Replacement: passo 3, immagine 1 di 3 Hover-1 Titan Right Gyroscope Replacement: passo 3, immagine 2 di 3 Hover-1 Titan Right Gyroscope Replacement: passo 3, immagine 3 di 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: passo 4, immagine 1 di 2 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: passo 4, immagine 2 di 2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Right Gyroscope Replacement: passo 5, immagine 1 di 3 Hover-1 Titan Right Gyroscope Replacement: passo 5, immagine 2 di 3 Hover-1 Titan Right Gyroscope Replacement: passo 5, immagine 3 di 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Right Gyroscope Replacement: passo 6, immagine 1 di 2 Hover-1 Titan Right Gyroscope Replacement: passo 6, immagine 2 di 2
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Right Gyroscope Replacement: passo 7, immagine 1 di 2 Hover-1 Titan Right Gyroscope Replacement: passo 7, immagine 2 di 2
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  8. Hover-1 Titan Right Gyroscope Replacement: passo 8, immagine 1 di 2 Hover-1 Titan Right Gyroscope Replacement: passo 8, immagine 2 di 2
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Right Gyroscope Replacement: passo 9, immagine 1 di 2 Hover-1 Titan Right Gyroscope Replacement: passo 9, immagine 2 di 2
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Hover-1 Titan Right Gyroscope Replacement: passo 10, immagine 1 di 1
    • Cut the cable tie and unplug the remaining wires.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S15-G4, White Fall 2018 Membro di Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Membri
10 Guide realizzate
Un commento
Where can I get the circuit boards for the left and right ?
jfsucher - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,063
