Salta al contenuto principale
Hover-1 Titan Power Button Replacement
Cosa ti serve
  1. Hover-1 Titan Power Button Replacement, Bottom Right Panel: passo 1, immagine 1 di 2 Hover-1 Titan Power Button Replacement, Bottom Right Panel: passo 1, immagine 2 di 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Power Button Replacement: passo 2, immagine 1 di 2 Hover-1 Titan Power Button Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Power Button Replacement: passo 3, immagine 1 di 3 Hover-1 Titan Power Button Replacement: passo 3, immagine 2 di 3 Hover-1 Titan Power Button Replacement: passo 3, immagine 3 di 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Power Button Replacement, Power Button: passo 4, immagine 1 di 2 Hover-1 Titan Power Button Replacement, Power Button: passo 4, immagine 2 di 2
    • Disconnect the battery by holding the yellow connectors and pulling apart.
  5. Hover-1 Titan Power Button Replacement: passo 5, immagine 1 di 3 Hover-1 Titan Power Button Replacement: passo 5, immagine 2 di 3 Hover-1 Titan Power Button Replacement: passo 5, immagine 3 di 3
    • Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board.
    • You can also unplug the light connector to free up your work space.
  6. Hover-1 Titan Power Button Replacement: passo 6, immagine 1 di 2 Hover-1 Titan Power Button Replacement: passo 6, immagine 2 di 2
    • Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
  7. Hover-1 Titan Power Button Replacement: passo 7, immagine 1 di 3 Hover-1 Titan Power Button Replacement: passo 7, immagine 2 di 3 Hover-1 Titan Power Button Replacement: passo 7, immagine 3 di 3
    • Pull the power button out of the panel.
    • Replace the power button.
Conclusione
Cal Poly, Team S15-G4, White Fall 2018 Membro di Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 723
