Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Parti
Nessuna parte specificata.
  1. Flip the hoverboard so the bottom is facing up. The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  4. Grip the bottom right panel and lift to remove it. Grip the bottom right panel and lift to remove it. Grip the bottom right panel and lift to remove it.
    • Grip the bottom right panel and lift to remove it.
Conclusione
Dana Ebe
Membro da: 08/10/2018
196 Reputazione
2 Guide realizzate
Cal Poly, Team S15-G4, White Fall 2018 Membro di Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 36
