Cosa ti serve
Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
