Introduzione
If your Hover-1 Titan battery will no longer hold a charge or your device will not turn on, use this guide to remove and replace your battery.
Cosa ti serve
Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
