Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
If your Hover-1 Titan battery will no longer hold a charge or your device will not turn on, use this guide to remove and replace your battery.
Parti
Nessuna parte specificata.
  1. Flip the hoverboard so the bottom is facing up. The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Grip the bottom right panel and lift to remove it. Grip the bottom right panel and lift to remove it. Grip the bottom right panel and lift to remove it.
    • Grip the bottom right panel and lift to remove it.
  4. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  5. Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart. Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  6. Remove the bundle of wires from the clip on the top of the battery. Remove the bundle of wires from the clip on the top of the battery.
    • Remove the bundle of wires from the clip on the top of the battery.
  7. Using a Phillips #1 screwdriver, remove the four 14  mm screws that hold the battery on the device. Using a Phillips #1 screwdriver, remove the four 14  mm screws that hold the battery on the device.
    • Using a Phillips #1 screwdriver, remove the four 14 mm screws that hold the battery on the device.
  8. Remove the battery out of the hoverboard by lifting the battery then sliding it out from under the wires. Remove the battery out of the hoverboard by lifting the battery then sliding it out from under the wires. Remove the battery out of the hoverboard by lifting the battery then sliding it out from under the wires.
    • Remove the battery out of the hoverboard by lifting the battery then sliding it out from under the wires.
Conclusione
Jessica Ouyang
Membro da: 08/10/2018
547 Reputazione
4 Guide realizzate
Cal Poly, Team S15-G4, White Fall 2018 Membro di Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 330
