Salta al contenuto principale
Hover-1 Superstar Speaker Replacement
Cosa ti serve
  1. Hover-1 Superstar Speaker Replacement, Bottom Case: passo 1, immagine 1 di 3 Hover-1 Superstar Speaker Replacement, Bottom Case: passo 1, immagine 2 di 3 Hover-1 Superstar Speaker Replacement, Bottom Case: passo 1, immagine 3 di 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Speaker Replacement: passo 2, immagine 1 di 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Speaker Replacement, Speaker: passo 3, immagine 1 di 1
    • Unplug the white connector that connects the speaker itself with the circuit board attached to the bottom of the device case.
  4. Hover-1 Superstar Speaker Replacement: passo 4, immagine 1 di 1
    • Unscrew all three 9mm screws with a Phillips #0 screwdriver securing the speaker to the device case.
  5. Hover-1 Superstar Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the speaker from its port.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 286
