Salta al contenuto principale
Hover-1 Superstar Right Gyroscope Sensor Sensor Board
Cosa ti serve
  1. Hover-1 Superstar Right Gyroscope Sensor Sensor Board, Bottom Case: passo 1, immagine 1 di 3 Hover-1 Superstar Right Gyroscope Sensor Sensor Board, Bottom Case: passo 1, immagine 2 di 3 Hover-1 Superstar Right Gyroscope Sensor Sensor Board, Bottom Case: passo 1, immagine 3 di 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 2, immagine 1 di 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Right Gyroscope Sensor Sensor Board, Right Gyroscope Sensor Board: passo 3, immagine 1 di 2 Hover-1 Superstar Right Gyroscope Sensor Sensor Board, Right Gyroscope Sensor Board: passo 3, immagine 2 di 2
    • Cut both zip-ties that secure the circuit board box and the wire bundle near the center of the device together.
  4. Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 4, immagine 1 di 3 Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 4, immagine 2 di 3 Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 4, immagine 3 di 3
    • Unplug all three of the cables that were previously zip-tied. They are the cables that are connected with a clear sleeve near the center of the device.
  5. Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 5, immagine 1 di 3 Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 5, immagine 2 di 3 Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 5, immagine 3 di 3
    • Unplug the colored connectors feeding through the top of the circuit board box. For the most part the colors correspond to each other, but make sure to take pictures to remember which connector goes in the correct position.
    • Unplug the yellow connector at the top right corner of the circuit board box.
  6. Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 6, immagine 1 di 3 Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 6, immagine 2 di 3 Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 6, immagine 3 di 3
    • Using a Phillips #1 screwdriver, remove the four 14mm screws securing the circuit board box in place.
    • Remove the circuit board box from the hoverboard.
  7. Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 7, immagine 1 di 2 Hover-1 Superstar Right Gyroscope Sensor Sensor Board: passo 7, immagine 2 di 2
    • Unclip the top of the circuit board box from the bottom.
    • Remove the balance sensor circuit board.
Conclusione
Altre 5 persone hanno completato questa guida.
4Commenti sulla guida
I’m trying to repair a hover-1 Allstar for my nephew. I thought I salved it by purchasing a new board but once I plugged it back in I have the same symptoms. Those symptoms are once it’s turned on it will immediately start to beep and the red battery light turns on. Nothing I do will get it to stop beeping unless I turn it off. The battery is fully charged, so the only other thing that came to mind was to check the motor hall sensors. Those all worked and tested perfectly. I’m out of ideas, can anyone help me?
Steve Davis - Replica
Good luck with getting some help. I been trying to find a circuit board for my grandson and no one will respond. The one I found on line does not match the one on the Hover-1 all star.
Wilbert Mcclamb - Replica
I am trying to find a board for the all-star as one of the connections has 6 wires the white being the xtra one. All the boards I look at are 5 wires. Did you locate a board?
markrichardowen -
I need a motherboard for a hover 1 charger hi- col. Where can I find one?
clint36092 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,957
