Salta al contenuto principale
Hover-1 Rally Rear Wheel Replacement
Cosa ti serve
  1. Hover-1 Rally Rear Wheel Replacement, Rear Wheel: passo 1, immagine 1 di 1
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
  2. Hover-1 Rally Rear Wheel Replacement: passo 2, immagine 1 di 1
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
  3. Hover-1 Rally Rear Wheel Replacement: passo 3, immagine 1 di 2 Hover-1 Rally Rear Wheel Replacement: passo 3, immagine 2 di 2
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
  4. Hover-1 Rally Rear Wheel Replacement: passo 4, immagine 1 di 1
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
Conclusione
Cami Lowrey
Membro da: 02/07/20
435 Reputazione
3 Guide realizzate
Cal Poly, Team S7-G2, Regan Winter 2020 Membro di Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 Membri
7 Guide realizzate
Un commento
Where can I buy replacement tires/wheels for the hover-1 rally scooter?
Josh Hatt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 867
