Salta al contenuto principale
Hover-1 Rally Headlight Replacement
Cosa ti serve
  1. Hover-1 Rally Headlight Replacement, Headlight: passo 1, immagine 1 di 2 Hover-1 Rally Headlight Replacement, Headlight: passo 1, immagine 2 di 2
    • Remove four 5 mm screws with a 5 mm hex key.
    • When reinstalling, gently tighten each screw simultaneously to apply equal pressure on both sides of the casing.
  2. Hover-1 Rally Headlight Replacement: passo 2, immagine 1 di 1
    • Apply pressure to both ends of the headlight to remove it from the scooter.
    • Be gentle. You will feel some resistance due to the glue that is used.
  3. Hover-1 Rally Headlight Replacement: passo 3, immagine 1 di 1
    • Once the headlight is loose from the scooter, disconnect the two wires using a soldering iron.
    • Use this soldering guide for tips on using a soldering iron.
Conclusione
Cami Lowrey
Membro da: 02/07/20
441 Reputazione
3 Guide realizzate
Cal Poly, Team S7-G2, Regan Winter 2020 Membro di Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 511
