Salta al contenuto principale
Hover-1 Rally Brake Pad Replacement
Cosa ti serve
  1. Hover-1 Rally Brake Pad Replacement, Rear Wheel: passo 1, immagine 1 di 1
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
  2. Hover-1 Rally Brake Pad Replacement: passo 2, immagine 1 di 1
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
  3. Hover-1 Rally Brake Pad Replacement: passo 3, immagine 1 di 2 Hover-1 Rally Brake Pad Replacement: passo 3, immagine 2 di 2
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
  4. Hover-1 Rally Brake Pad Replacement: passo 4, immagine 1 di 1
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
  5. Hover-1 Rally Brake Pad Replacement, Brake Pad: passo 5, immagine 1 di 1
    • Begin by removing the two 8.0 mm screws from the deck using the Phillips #2 screwdriver.
    • Two screw caps will come off with the screws
  6. Hover-1 Rally Brake Pad Replacement: passo 6, immagine 1 di 1
    • Pull the foot brake/ wheel cover away from the deck and downwards.
  7. Hover-1 Rally Brake Pad Replacement: passo 7, immagine 1 di 1
    • On the foot brake, remove the two 8.0 mm screws using the Phillips #2 screwdriver.
  8. Hover-1 Rally Brake Pad Replacement: passo 8, immagine 1 di 1
    • On the opposite side of the brake, remove the silver brake pad.
    • If this is your first time replacing this part, the removal might require more force. You may need to use the flat end of a spudger to pry it off.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S7-G2, Regan Winter 2020 Membro di Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 23
Tutti i Tempi: 656
