Salta al contenuto principale
Hover-1 Maverick Motor Wheel Replacement
Cosa ti serve
  1. Hover-1 Maverick Motor Wheel Replacement, Motherboard: passo 1, immagine 1 di 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: passo 1, immagine 2 di 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: passo 1, immagine 3 di 3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motor Wheel Replacement: passo 2, immagine 1 di 2 Hover-1 Maverick Motor Wheel Replacement: passo 2, immagine 2 di 2
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motor Wheel Replacement: passo 3, immagine 1 di 2 Hover-1 Maverick Motor Wheel Replacement: passo 3, immagine 2 di 2
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motor Wheel Replacement: passo 4, immagine 1 di 2 Hover-1 Maverick Motor Wheel Replacement: passo 4, immagine 2 di 2
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
  5. Hover-1 Maverick Motor Wheel Replacement, Motor: passo 5, immagine 1 di 2 Hover-1 Maverick Motor Wheel Replacement, Motor: passo 5, immagine 2 di 2
    • After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench.
    • Remove the metal covering from over the motor.
  6. Hover-1 Maverick Motor Wheel Replacement: passo 6, immagine 1 di 1
    • The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
Conclusione
Piper Feldman
Membro da: 01/23/20
409 Reputazione
4 Guide realizzate
Cal Poly, Team S2-G2, White Winter 2020 Membro di Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 484
