Salta al contenuto principale
Hover-1 Maverick Battery Replacement
Cosa ti serve
  1. Hover-1 Maverick Battery Replacement, Battery: passo 1, immagine 1 di 2 Hover-1 Maverick Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Remove the shell.
  2. Hover-1 Maverick Battery Replacement: passo 2, immagine 1 di 3 Hover-1 Maverick Battery Replacement: passo 2, immagine 2 di 3 Hover-1 Maverick Battery Replacement: passo 2, immagine 3 di 3
    • Remove the four 8mm Phillips #1 screws holding down the black plastic casing.
    • Lift off the black plastic retaining bracket.
  3. Hover-1 Maverick Battery Replacement: passo 3, immagine 1 di 2 Hover-1 Maverick Battery Replacement: passo 3, immagine 2 di 2
    • Pull the battery upward lightly to remove from the device.
    • The battery is secured to the device with adhesive tape.
Conclusione
Piper Feldman
Membro da: 01/23/20
409 Reputazione
4 Guide realizzate
Cal Poly, Team S2-G2, White Winter 2020 Membro di Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 Membri
4 Guide realizzate
2 Commenti
What voltage should the battery put out? Mines is 30v, charger is green at the wall but still the board won’t turn on
Barry Rogers - Replica
Where can I find that same battery i cant find one
Toad Blue - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 46
Tutti i Tempi: 2,961
