Salta al contenuto principale
Hover-1 Matrix Pad Replacement
Cosa ti serve
  1. Hover-1 Matrix Pad Replacement, Pad: passo 1, immagine 1 di 2 Hover-1 Matrix Pad Replacement, Pad: passo 1, immagine 2 di 2
    • Remove the screws on the back of the hoverboard using a Phillips #1 screwdriver.
    • Remove the back shell from the hoverboard.
  2. Hover-1 Matrix Pad Replacement: passo 2, immagine 1 di 1
    • Remove the screws from the metal layer inside the hoverboard using a Phillips #1 screwdriver.
  3. Hover-1 Matrix Pad Replacement: passo 3, immagine 1 di 1
    • Separate the upper shell of the hoverboard and the metal layer inside.
  4. Hover-1 Matrix Pad Replacement: passo 4, immagine 1 di 2 Hover-1 Matrix Pad Replacement: passo 4, immagine 2 di 2
    • Start by identifying the motherboard, which is the green pad shown in the picture.
    • Remove the screws on the corners of the motherboard with the Phillips #1 screwdriver and take it off.
    • There are cables attached to the motherboard so go ahead and unattach them.
  5. Hover-1 Matrix Pad Replacement: passo 5, immagine 1 di 3 Hover-1 Matrix Pad Replacement: passo 5, immagine 2 di 3 Hover-1 Matrix Pad Replacement: passo 5, immagine 3 di 3
    • Use picture 1 as a guide and move the motherboard to the other side.
    • Identify the two black rubber buttons that are shown in the second picture.
    • Remove the two rubber buttons using the Phillips #1 screwdriver.
  6. Hover-1 Matrix Pad Replacement: passo 6, immagine 1 di 1
    • Removing the rubber buttons in the previous step allows you to take the pad off.
    • Finally, take off the old pad and put on a new pad.
Conclusione
To reassemble your device, follow these instructions starting with step number 6 and finishing with step number 1.
Jici Zhuang
Membro da: 10/22/18
362 Reputazione
2 Guide realizzate
UC Davis, Team S7-G2, Lore Fall 2018 Membro di UC Davis, Team S7-G2, Lore Fall 2018
UCD-LORE-F18S7G2
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 350
