Introduzione
If the hoverboard is unwilling to move and it is fully charged, there may be an issue with the wheel motors.
Cosa ti serve
Flip the hoverboard over so the labels are facing upwards.
Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
Place the hoverboard so the four 36mm Allen bolts are pointing up.
Remove the four 36mm Allen bolts on each side using a 5mm Allen Wrench.
Altre 3 persone hanno completato questa guida.
2 Commenti
My bracket the wheel attaches to hoverboard is broke can that portion of board be replaced? Where can I buy it if so?
Can I buy a replacement battery side motor for hover1 drive hoverboard. If so, where? Can’t seem to find it on internet
