Salta al contenuto principale
Hover-1 Liberty Bottom Cover Replacement
Cosa ti serve
  1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: passo 1, immagine 1 di 2 Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Bottom Cover Replacement: passo 2, immagine 1 di 2 Hover-1 Liberty Bottom Cover Replacement: passo 2, immagine 2 di 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Bottom Cover Replacement: passo 3, immagine 1 di 3 Hover-1 Liberty Bottom Cover Replacement: passo 3, immagine 2 di 3 Hover-1 Liberty Bottom Cover Replacement: passo 3, immagine 3 di 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
Conclusione
Altre 2 persone hanno completato questa guida.
Patrick Bacon
Membro da: 10/08/18
411 Reputazione
2 Guide realizzate
Cal Poly, Team S13-G2, White Fall 2018 Membro di Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Membri
4 Guide realizzate
2 Commenti
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - Replica
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 3,115
