Salta al contenuto principale
Hover-1 Liberty Battery Replacement
Cosa ti serve
  1. Hover-1 Liberty Battery Replacement, Bottom Cover: passo 1, immagine 1 di 2 Hover-1 Liberty Battery Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Battery Replacement: passo 2, immagine 1 di 2 Hover-1 Liberty Battery Replacement: passo 2, immagine 2 di 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Battery Replacement: passo 3, immagine 1 di 3 Hover-1 Liberty Battery Replacement: passo 3, immagine 2 di 3 Hover-1 Liberty Battery Replacement: passo 3, immagine 3 di 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Battery Replacement, Battery: passo 4, immagine 1 di 2 Hover-1 Liberty Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Disconnect the large red and black wire from the battery by pulling apart the connector.
  5. Hover-1 Liberty Battery Replacement: passo 5, immagine 1 di 2 Hover-1 Liberty Battery Replacement: passo 5, immagine 2 di 2
    • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
  6. Hover-1 Liberty Battery Replacement: passo 6, immagine 1 di 2 Hover-1 Liberty Battery Replacement: passo 6, immagine 2 di 2
    • Remove the bracket by pulling it upwards, away from the hoverboard.
    • You will need to move some wires aside to remove the bracket successfully.
  7. Hover-1 Liberty Battery Replacement: passo 7, immagine 1 di 3 Hover-1 Liberty Battery Replacement: passo 7, immagine 2 di 3 Hover-1 Liberty Battery Replacement: passo 7, immagine 3 di 3
    • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
    • The battery is held in place by adhesive. So, some force is required to remove it.
Conclusione
Patrick Bacon
Membro da: 10/08/18
411 Reputazione
2 Guide realizzate
Cal Poly, Team S13-G2, White Fall 2018 Membro di Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,535
