Introduzione
Is one side of the hoverboard not functioning, or unresponsive? This is a guide to show you how to replace the wheel, or motor (which is apart of the wheel) on the Hover-1 Horizon. This guide requires a Phillips #2 and a Phillips #1 screwdriver, and a 6mm hex key.
Cosa ti serve
Remove the two connectors on either side of the board by lifting the tab and pulling out.
Remove the connector in the middle of the board by squeezing the tab and pulling up.
Remove the four 30mm Hex #6 screws.
Lift away the silver bracket and set it to the side.
