Salta al contenuto principale
Introduzione
Are your wheels experiencing resistance while turning? This is a guide to show you how to check and replace the wires that connect the wheel to the motherboard. This guide requires a Phillips #2 and a Phillips #1 screwdriver, and a 6 mm hex key.
  1. Remove the six 12mm Phillips #2 screws holding the base plate. Remove the six 12mm Phillips #2 screws holding the base plate.
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Remove the two 11mm Phillips #1 screws that hold the base plate to the body. Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Remove the base plate by lifting it up. The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side. The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Remove the two connectors on either side of the board by lifting the tab and pulling out. Remove the connector in the middle of the board by squeezing the tab and pulling up. Remove the connector in the middle of the board by squeezing the tab and pulling up.
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Remove the four 11mm Phillips #1 screws that hold the cover on. Remove the four 11mm Phillips #1 screws that hold the cover on.
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  7. Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount. Lift the board to reveal the connections on the bottom. Lift the board to reveal the connections on the bottom.
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  8. Remove the middle connector by squeezing the top of the tab and pulling up. Remove the middle connector by squeezing the top of the tab and pulling up.
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  9. Remove the four 12mm Phillips #2 screws that hold the motherboard to the base. Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right . Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  10. Unclip the black connector by squeezing both sides and pulling them apart. Unclip the black connector by squeezing both sides and pulling them apart. Unclip the black connector by squeezing both sides and pulling them apart.
    • Unclip the black connector by squeezing both sides and pulling them apart.
  11. Remove the four 30mm Hex #6 screws. Remove the four 30mm Hex #6 screws.
    • Remove the four 30mm Hex #6 screws.
  12. Remove the metal square by lifting it up and setting it to the side. Remove the metal square by lifting it up and setting it to the side. Remove the metal square by lifting it up and setting it to the side.
    • Remove the metal square by lifting it up and setting it to the side.
  13. Check that all the clips are secured properly.
    • Check that all the clips are secured properly.
  14. Remove the clip by squeezing the latch that holds the clips together while pulling apart. Check motion of the wheel after the clip is disconnected. If the wheel is still stuck, reconnect the clip and disconnect the next one. Remove the clip by squeezing the tab while pulling the clip apart.
    • Remove the clip by squeezing the latch that holds the clips together while pulling apart.
    • Check motion of the wheel after the clip is disconnected. If the wheel is still stuck, reconnect the clip and disconnect the next one.
    • Remove the clip by squeezing the tab while pulling the clip apart.
  15. Disconnect the remaining three clips by pulling them apart. After each clip is disconnected, check to see if the motion of the wheel has improved. If the wheel is still stuck, reconnect the clip and unclip the next one. After each clip is disconnected, check to see if the motion of the wheel has improved. If the wheel is still stuck, reconnect the clip and unclip the next one.
    • Disconnect the remaining three clips by pulling them apart.
    • After each clip is disconnected, check to see if the motion of the wheel has improved. If the wheel is still stuck, reconnect the clip and unclip the next one.
Conclusione
Jenny Dyer
Membro da: 08/10/2018
232 Reputazione
2 Guide realizzate
Cal Poly, Team S13-G6, White Fall 2018 Membro di Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 66
