Introduzione
Is your hoverboard unbalanced or leaning to one side while riding? This is a guide to show you how to remove the left balance sensor tab on the Hover-1 Horizon, the most likely culprit to your problem. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
Cosa ti serve
Remove the two connectors on either side of the board by lifting the tab and pulling out.
Remove the connector in the middle of the board by squeezing the tab and pulling up.
Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
