Salta al contenuto principale
Introduzione
To access the internal components of the hoverboard, the base plate must be removed. This guide will show you how to remove the base plate of your Hover-1 Horizon.
Parti
Nessuna parte specificata.
  1. Remove the six 12mm Phillips #2 screws holding the base plate. Remove the six 12mm Phillips #2 screws holding the base plate.
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  3. Remove the two 11mm Phillips #1 screws that hold the base plate to the body. Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  4. Remove the base plate by lifting it up. The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side. The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
Conclusione
Jenny Dyer
Membro da: 08/10/2018
232 Reputazione
2 Guide realizzate
Cal Poly, Team S13-G6, White Fall 2018 Membro di Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 24
