Introduzione
This guide explains how to remove the sensor assembly for your Hover-1 H1 hover board.
Parti
Nessuna parte specificata.
  1. Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Puncture the two black stickers by using the tip of a screwdriver.
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Lift each side of the bottom shell by pulling up. When lifting the shell, take care to not tear any cables from their connectors.
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Unplug the battery by pulling gently on both sides of the orange connector.
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up. On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
  6. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  7. Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector. Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  8. Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise. Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  9. Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
  10. Remove the hot glue holding in the connectors with a utility knife. Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up. Be careful not to touch any parts of the circuit boards with the knife.
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
  11. Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  12. Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up. Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
  13. Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise. Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  14. Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
Conclusione
Aaron Teh
Membro da: 08/10/2018
253 Reputation
2 Guide realizzate
Cal Poly, Team S17-G6, White Fall 2018 Membro di Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Membri
7 Guide realizzate
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 251
