Introduzione
This guide explains how to remove the sensor assembly for your Hover-1 H1 hover board.
Cosa ti serve
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
Altre 5 persone hanno completato questa guida.
