Salta al contenuto principale
Hover-1 H1 Bottom Shell Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Hover-1 H1 Bottom Shell Replacement, Bottom Shell: passo 1, immagine 1 di 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Bottom Shell Replacement: passo 2, immagine 1 di 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Bottom Shell Replacement: passo 3, immagine 1 di 2 Hover-1 H1 Bottom Shell Replacement: passo 3, immagine 2 di 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Bottom Shell Replacement: passo 4, immagine 1 di 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
Conclusione
Cal Poly, Team S17-G6, White Fall 2018 Membro di Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 43
