Salta al contenuto principale
Hover-1 H1 Battery Replacement
Cosa ti serve
  1. Hover-1 H1 Battery Replacement, Bottom Shell: passo 1, immagine 1 di 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Battery Replacement: passo 2, immagine 1 di 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Battery Replacement: passo 3, immagine 1 di 2 Hover-1 H1 Battery Replacement: passo 3, immagine 2 di 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Battery Replacement: passo 4, immagine 1 di 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  6. Hover-1 H1 Battery Replacement: passo 6, immagine 1 di 1
    • Gently lift the battery harness and remove the battery by lifting the battery and moving it away from the hoverboard.
Conclusione
Altre 4 persone hanno completato questa guida.
Aaron Teh
Membro da: 10/08/18
442 Reputazione
2 Guide realizzate
Cal Poly, Team S17-G6, White Fall 2018 Membro di Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Membri
7 Guide realizzate
11 Commenti
The stickers were the trick. I didn’t see them!
Daniel D - Replica
After removing the 4 screws that is holding the battery in place I still can't remove the battery. I tried gently to pry under the battery but it doesn't budge. Uni Sun model HY-A01B. How do I solve this problem?
Terry Pollard - Replica
Where do I get another battery to replace it???
Tony Pate - Replica
That's the question I can't seem to find the answer to
Darin -
Very low quality. Bought for my son who haven’t even used it for 15 times. Got it during winter and before summer the product stopped working.
tosin3in1 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 178
Tutti i Tempi: 9,278
