Salta al contenuto principale
Hover-1 Folding E-Scooter Rear Wheel Replacement
Cosa ti serve
  1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: passo 1, immagine 1 di 2 Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: passo 1, immagine 2 di 2
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 2, immagine 1 di 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 2, immagine 2 di 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 2, immagine 3 di 3
    • Slide off the plastic side panel.
  3. Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 3, immagine 1 di 1
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 4, immagine 1 di 1
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 5, immagine 1 di 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 5, immagine 2 di 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 5, immagine 3 di 3
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Rear Wheel Replacement: passo 6, immagine 1 di 1
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
Conclusione
Luke Imai
Membro da: 10/08/18
133 Reputazione
1 Guida realizzata
Cal Poly, Team S15-G5, White Fall 2018 Membro di Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Membri
5 Guide realizzate
2 Commenti
Where can you get replacement rubber for the front and rear wheels?
jackricotta - Replica
How about adding a rear wheel removal article for the Hover-1 Alpha folding scooter?
sfaheysd - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 36
Tutti i Tempi: 5,158
