Salta al contenuto principale
Hover-1 Folding E-Scooter LED Headlight Replacement
Cosa ti serve
  1. Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: passo 1, immagine 1 di 2 Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: passo 1, immagine 2 di 2
    • Face the front of the scooter towards you.
    • Remove all four 24mm bolts by turning counterclockwise using the Hex 4 screwdriver bit.
  2. Hover-1 Folding E-Scooter LED Headlight Replacement: passo 2, immagine 1 di 2 Hover-1 Folding E-Scooter LED Headlight Replacement: passo 2, immagine 2 di 2
    • Remove the headlight housing.
    • The LED should release when you take off the cover.
    • Be careful when taking off the cover; the light is glued onto the cover and could harm the device.
  3. Hover-1 Folding E-Scooter LED Headlight Replacement: passo 3, immagine 1 di 2 Hover-1 Folding E-Scooter LED Headlight Replacement: passo 3, immagine 2 di 2
    • Disconnect the red wire using a soldering iron.
    • The soldering iron should melt the glue for you, so don't worry about removing it yourself.
  4. Hover-1 Folding E-Scooter LED Headlight Replacement: passo 4, immagine 1 di 1
    • For ease of installation, tin your new LED and the connecting wire with the soldering iron and solder.
    • Solder your new light on to the existing red wire.
    • For help on how to solder, refer to iFixit's Soldering Guide.
Conclusione
To reassemble your device, follow these instructions in reverse order with the new LED.
Cal Poly, Team S15-G5, White Fall 2018 Membro di Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,137
