Salta al contenuto principale
Hover-1 Folding E-Scooter Deck Replacement
Cosa ti serve
  1. Hover-1 Folding E-Scooter Deck Replacement, Rear Wheel: passo 1, immagine 1 di 2 Hover-1 Folding E-Scooter Deck Replacement, Rear Wheel: passo 1, immagine 2 di 2
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Deck Replacement: passo 2, immagine 1 di 3 Hover-1 Folding E-Scooter Deck Replacement: passo 2, immagine 2 di 3 Hover-1 Folding E-Scooter Deck Replacement: passo 2, immagine 3 di 3
    • Slide off the plastic side panel.
  3. Hover-1 Folding E-Scooter Deck Replacement: passo 3, immagine 1 di 1
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Deck Replacement: passo 4, immagine 1 di 1
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Deck Replacement: passo 5, immagine 1 di 3 Hover-1 Folding E-Scooter Deck Replacement: passo 5, immagine 2 di 3 Hover-1 Folding E-Scooter Deck Replacement: passo 5, immagine 3 di 3
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Deck Replacement: passo 6, immagine 1 di 1
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
  7. Hover-1 Folding E-Scooter Deck Replacement, Brake Pad: passo 7, immagine 1 di 2 Hover-1 Folding E-Scooter Deck Replacement, Brake Pad: passo 7, immagine 2 di 2
    • Remove the two 25mm screws by twisting a Phillips #2 screwdriver counterclockwise.
    • Twist the screwdriver clockwise to reassemble.
    • There are also two nuts that secure the screws.
  8. Hover-1 Folding E-Scooter Deck Replacement: passo 8, immagine 1 di 3 Hover-1 Folding E-Scooter Deck Replacement: passo 8, immagine 2 di 3 Hover-1 Folding E-Scooter Deck Replacement: passo 8, immagine 3 di 3
    • Wobble to remove the brake step.
  9. Hover-1 Folding E-Scooter Deck Replacement: passo 9, immagine 1 di 2 Hover-1 Folding E-Scooter Deck Replacement: passo 9, immagine 2 di 2
    • Remove the two 8 mm screws by twisting a Phillips #2 screwdriver counterclockwise.
    • Twist the screwdriver clockwise to secure the screws.
  10. Hover-1 Folding E-Scooter Deck Replacement: passo 10, immagine 1 di 3 Hover-1 Folding E-Scooter Deck Replacement: passo 10, immagine 2 di 3 Hover-1 Folding E-Scooter Deck Replacement: passo 10, immagine 3 di 3
    • Remove the brake pad.
  11. Hover-1 Folding E-Scooter Deck Replacement, Deck: passo 11, immagine 1 di 3 Hover-1 Folding E-Scooter Deck Replacement, Deck: passo 11, immagine 2 di 3 Hover-1 Folding E-Scooter Deck Replacement, Deck: passo 11, immagine 3 di 3
    • Hold the two 10mm nuts in place with a 10mm wrench.
    • Remove the two 33mm bolts connected to the 10 mm nuts by turning a hex 4.0 screwdriver counterclockwise.
    • The nuts are on the bottom of the deck.
    • Turn clockwise to reassemble the bolts.
  12. Hover-1 Folding E-Scooter Deck Replacement: passo 12, immagine 1 di 2 Hover-1 Folding E-Scooter Deck Replacement: passo 12, immagine 2 di 2
    • Fold the scooter by releasing the latch and pushing the handlebars to the rear of the device.
  13. Hover-1 Folding E-Scooter Deck Replacement: passo 13, immagine 1 di 3 Hover-1 Folding E-Scooter Deck Replacement: passo 13, immagine 2 di 3 Hover-1 Folding E-Scooter Deck Replacement: passo 13, immagine 3 di 3
    • Hold the two hex nuts in place with a 10mm wrench.
    • Remove the next two 33 mm bolts attached to the 10 mm hex nuts by turning a hex 4.0 screwdriver counterclockwise.
    • The deck will fall off after you remove the final bolts.
    • Turn the hex bit clockwise to reassemble.
Conclusione
To reassemble your device, follow these instructions in reverse order and use the new deck instead.
Cal Poly, Team S15-G5, White Fall 2018 Membro di Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Membri
5 Guide realizzate
2 Commenti
The latch does not operate properly and is missing a part on the right side so it cannot retract the steel bar that locks the position. What part do I need and can you pls send it? It’s a brand new unit.
Original NYC ScooterCommuter - Replica
step 7 is where mine is broken .. it was kicked hard and right after the 2 screws but before the curb has been snapped what do i do
Tiffany Trevino - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,124
