Salta al contenuto principale
Hover-1 Folding E-Scooter Brake Switch Replacement
Cosa ti serve
  1. Hover-1 Folding E-Scooter Brake Switch Replacement, Brake Switch: passo 1, immagine 1 di 1
    • Twist the handle with the red level counterclockwise to remove it from the scooter's main body.
    • You will need to twist the handle clockwise reattach it to the scooter's main body.
  2. Hover-1 Folding E-Scooter Brake Switch Replacement: passo 2, immagine 1 di 2 Hover-1 Folding E-Scooter Brake Switch Replacement: passo 2, immagine 2 di 2
    • Remove the four 5 mm screws twisting counterclockwise with a Phillips #0 screwdriver.
    • These screws are small and easy to lose.
    • When inserting for reassembly the screws twist clockwise to secure.
  3. Hover-1 Folding E-Scooter Brake Switch Replacement: passo 3, immagine 1 di 3 Hover-1 Folding E-Scooter Brake Switch Replacement: passo 3, immagine 2 di 3 Hover-1 Folding E-Scooter Brake Switch Replacement: passo 3, immagine 3 di 3
    • Remove the red brake switch by sliding it off the main body.
    • When putting the brake switch back make sure to align the tab with the throttle switch.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S15-G5, White Fall 2018 Membro di Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Membri
5 Guide realizzate
6 Commenti
Do you know where I can find just the handle? They sent me a L and R but the L was stripped and won't screw in and the R will screw into both sides so I need either a L or R at this point I don't care i just can't find one and its “out of warranty”
Angela Renteria - Replica
Hi, I’m looking for a Hover-1 Eagle left handle?  Do you where can I find it? Thanks
Keila Talarico - Replica
looking for a new brake switch a hover-1 scooter,my grandson crashed and broke the brake switch. please help
Neal Weeks - Replica
Looking new break switch.where we will get?. please reply.
Vitesh - Replica
Looking for a throttle switch. Know where I can find one?
Mara - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 4,618
