Salta al contenuto principale
Hover-1 Coast Trucks Replacement
Cosa ti serve
  1. Hover-1 Coast Trucks Replacement, Trucks: passo 1, immagine 1 di 3 Hover-1 Coast Trucks Replacement, Trucks: passo 1, immagine 2 di 3 Hover-1 Coast Trucks Replacement, Trucks: passo 1, immagine 3 di 3
    • In order to remove the trucks on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using the pick tool to puncture the grip tape and reveal the screws.
    • The board should look like this.
  2. Hover-1 Coast Trucks Replacement: passo 2, immagine 1 di 3 Hover-1 Coast Trucks Replacement: passo 2, immagine 2 di 3 Hover-1 Coast Trucks Replacement: passo 2, immagine 3 di 3
    • Once all four screws have been revealed, locate the socket wrench and the Phillips #1 screwdriver in the wrench handle.
    • Place the 9/16 inch socket wrench over the nut; place the the Phillips #1 screwdriver in the screw.
    • Hold the socket wrench in place and twist the screwdriver counterclockwise to loosen the nuts.
  3. Hover-1 Coast Trucks Replacement: passo 3, immagine 1 di 3 Hover-1 Coast Trucks Replacement: passo 3, immagine 2 di 3 Hover-1 Coast Trucks Replacement: passo 3, immagine 3 di 3
    • Remove the nuts from the bottom of the board.
    • Slide the unwanted trucks off the screws.
    • The black rubber spacer will stay on the board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 249
