Salta al contenuto principale
Hover-1 Coast Board Battery Replacement
Cosa ti serve
  1. Hover-1 Coast Board Battery Replacement, Board Battery: passo 1, immagine 1 di 3 Hover-1 Coast Board Battery Replacement, Board Battery: passo 1, immagine 2 di 3 Hover-1 Coast Board Battery Replacement, Board Battery: passo 1, immagine 3 di 3
    • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using a pick tool, puncture the grip tape and expose the screws.
    • Loosen all four 1" screws using a Phillips #1 screwdriver.
  2. Hover-1 Coast Board Battery Replacement: passo 2, immagine 1 di 3 Hover-1 Coast Board Battery Replacement: passo 2, immagine 2 di 3 Hover-1 Coast Board Battery Replacement: passo 2, immagine 3 di 3
    • Now pull the black protective cover off the board.
    • Locate the battery.
  3. Hover-1 Coast Board Battery Replacement: passo 3, immagine 1 di 3 Hover-1 Coast Board Battery Replacement: passo 3, immagine 2 di 3 Hover-1 Coast Board Battery Replacement: passo 3, immagine 3 di 3
    • The battery is connected by these two sets of wires.
    • Remove the yellow wire first by pulling the two wires gently in opposite directions.
    • Now pull apart the black wire by gently pulling the two wires in opposite directions.
  4. Hover-1 Coast Board Battery Replacement: passo 4, immagine 1 di 3 Hover-1 Coast Board Battery Replacement: passo 4, immagine 2 di 3 Hover-1 Coast Board Battery Replacement: passo 4, immagine 3 di 3
    • Once the battery has been disconnected, gently pry the battery upward.
    • It is important to use a plastic opening tool to avoid puncturing the battery.
    • Once the battery is freed, remove it with your hands.
    • The battery is glued to the case and will require some effort to remove.
Conclusione
Un commento
Where can you order a replacement battery?
Phil - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 616
