Salta al contenuto principale
Hover-1 Chrome LED Headlights Replacement
Cosa ti serve
  1. Hover-1 Chrome LED Headlights Replacement, Hover-1 Chrome Disassembly: passo 1, immagine 1 di 1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome LED Headlights Replacement: passo 2, immagine 1 di 1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome LED Headlights Replacement: passo 3, immagine 1 di 2 Hover-1 Chrome LED Headlights Replacement: passo 3, immagine 2 di 2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome LED Headlights Replacement, LED Headlights: passo 4, immagine 1 di 3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: passo 4, immagine 2 di 3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: passo 4, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
    • Remove the LED board.
    • The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
  5. Hover-1 Chrome LED Headlights Replacement: passo 5, immagine 1 di 2 Hover-1 Chrome LED Headlights Replacement: passo 5, immagine 2 di 2
    • Locate the LED headlights on the left side of the board.
    • Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
  6. Hover-1 Chrome LED Headlights Replacement: passo 6, immagine 1 di 3 Hover-1 Chrome LED Headlights Replacement: passo 6, immagine 2 di 3 Hover-1 Chrome LED Headlights Replacement: passo 6, immagine 3 di 3
Conclusione
Nick McGuire
Membro da: 10/08/18
551 Reputazione
4 Guide realizzate
Cal Poly, Team S4-G1, White Fall 2018 Membro di Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 191
