Introduzione
This guide will show you how to replace the charging port for your Hover-1 Eclipse. The charging port is where the charging cable plugs into the board. You may need to replace the charging port if your hover board is not charging correctly and the charging cable has already been replaced and/or ruled out as the root of the issue. In order to carry out this replacement, a knowledge of screwdriver usage and unplugging cords is needed.
Cosa ti serve
Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the left side bottom shell piece.
Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the left side bottom shell piece.
Pull back and set aside the left bottom shell halve. This shell half is still wired to rest of the hoverboard.
