Salta al contenuto principale
Hover 1 Eclipse Bluetooth Speaker Replacement
Cosa ti serve
  1. Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: passo 1, immagine 1 di 3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: passo 1, immagine 2 di 3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: passo 1, immagine 3 di 3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece
  2. Hover 1 Eclipse Bluetooth Speaker Replacement: passo 2, immagine 1 di 3 Hover 1 Eclipse Bluetooth Speaker Replacement: passo 2, immagine 2 di 3 Hover 1 Eclipse Bluetooth Speaker Replacement: passo 2, immagine 3 di 3
    • within the plug side shell piece, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • On the body of the board, follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the shell piece.
  3. Hover 1 Eclipse Bluetooth Speaker Replacement: passo 3, immagine 1 di 3 Hover 1 Eclipse Bluetooth Speaker Replacement: passo 3, immagine 2 di 3 Hover 1 Eclipse Bluetooth Speaker Replacement: passo 3, immagine 3 di 3
    • Using a Phillips #0 Screwdriver, remove the 3 screws holding the speaker to the shell.
    • Lift the speaker out from the casing.
Conclusione
Mina Dedijer
Membro da: 10/10/19
545 Reputazione
4 Guide realizzate
Cal Poly, Team S12-G4, Regan Fall 2019 Membro di Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 322
