Salta al contenuto principale
Hover 1 Eclipse Battery Replacement
  1. Hover 1 Eclipse Battery Replacement, Battery: passo 1, immagine 1 di 3 Hover 1 Eclipse Battery Replacement, Battery: passo 1, immagine 2 di 3 Hover 1 Eclipse Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the right side bottom shell piece.
  2. Hover 1 Eclipse Battery Replacement: passo 2, immagine 1 di 2 Hover 1 Eclipse Battery Replacement: passo 2, immagine 2 di 2
    • Locate the black and red wires connected by an yellow header, Xt60.
    • This wire connects the battery to the motherboard.
    • Carefully tug on the two sides of the yellow header to disconnect them.
  3. Hover 1 Eclipse Battery Replacement: passo 3, immagine 1 di 3 Hover 1 Eclipse Battery Replacement: passo 3, immagine 2 di 3 Hover 1 Eclipse Battery Replacement: passo 3, immagine 3 di 3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that secure the black plastic keeping the battery in place.
    • Carefully remove the black plastic from the hoverboard.
    • Be mindful of the wires surrounding the battery.
  4. Hover 1 Eclipse Battery Replacement: passo 4, immagine 1 di 2 Hover 1 Eclipse Battery Replacement: passo 4, immagine 2 di 2
    • Be careful with the wires surrounding the battery when executing this step.
    • The battery is attached to the metal with an adhesive.
    • Firmly grasp the battery and tug on it until it is free from the metal.
Conclusione
Mina Dedijer
Membro da: 10/10/19
545 Reputazione
4 Guide realizzate
Cal Poly, Team S12-G4, Regan Fall 2019 Membro di Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 32
Tutti i Tempi: 2,199
